Activity Forums Maxon Cinema 4D C4D 8.5 : crumple…
  • C4D 8.5 : crumple…
    Posted by Kelly Johnson on July 19, 2007 at 3:19 pm
    Hello-
    I’m trying to animate a ‘crumple’ effect. I’ve got a simple paper airplane model and I just want to crumple the tip a little when it hits something.
    I’ve tried key framing before and after crumple is applied (Structure:Edit Surface: Crumple) but I can’t get the crumple to keyframe… it crumples the entire model as if I ‘globally’ applied that.
    Is there some other technique or step I should be using to be able to do this?
    Brian Jones replied 19 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    July 20, 2007 at 2:49 am
    Yeah, like Matrix Extrude it’s one of those things that constructs but does not modify. Depending on what you are trying to do Crumple looks a lot like a fractal noise displacement in a material. That *can* be animated (but you can’t see it without something like DisplaceView in the discontinued Jenna).
    There is also Noise Deformer https://www.welter-4d.de/fplugs/freeplugins_en.html
    …and likely some obvious choices I’m not thinking of…
