C300 MXF files transfer to Apple Pro Res – FCP 7
I’m trying to edit a project in FCP 7.
Footage was shot on a C300. Using MXF Converter for MAC I am able to preview all the clips and convert them into APPLE PRO RES 422. However when I import the Apple Pro Res files into final cut pro 7 I get an error message:“The following media files are not optimized for Final Cut Pro” It is highly recommended that you either recapture the media or use the media Manager to create new copies of the files to improve their performance for multi-stream playback”
The clips show up as imported but I can’t view them – I get an error message “Out of Memory” when I try,
When I try to drag any clip into the sequence FCP bounces me out.Any guidance on which step to re-do – I am obviously doing sonething wrong – likely at the MXF Converter step.
Any help much appreciated
