Activity Forums Adobe Premiere Pro C300 MKII Editing workflow.
  • C300 MKII Editing workflow.
    Posted by Ben Lewis on July 18, 2016 at 5:02 pm
    Hi all,
    I’m looking for an efficient workflow for editing 4k footage shot on C300 MKII. The footage specs are as follows…
    Video:
    4K 4096 x 2160 (1.0)
    24fps
    XAVC
    Captured at
    10-bit 4:2:2
    410Mbps
    Audio:
    24-bit-4 Channel mapped to 4 Mono.
    My machine is…
    iMac (Retina 5K, 27-inch, Late 2015)
    4 GHz Intel Core i7
    32 GB 1867 MHz DDR3
    AMD Radeon R9 M395X 4096 MB
    I am aware of the fact the drives Im running from are only 5200rpm connected via usb3.
    I do have a 1TB LaCie d2 Quadra Hard Disk eSATA 3Gbits USB Firewire 400 & 800 but I’m not sure if that drive is 7200rpm and I would have to invest in either a thunderbolt to firewire 800 adapter or USB 3 to esata.
    I’ve considering transcoding the content to something like prores hq but not sure if this will smooth playback in premiere.
    I don’t have budget for new drives so ideally want to use my existing ones.
    Any suggestions for best editing workflows in this format would be greatly appreciated.
    Ben
    Ben Lewis replied 9 years, 2 months ago 3 Members · 5 Replies
  • Gary Huff
    July 18, 2016 at 11:53 pm
    Was the proxy functionality of the C300 Mark II used? I use this all the time, edit from the proxies, then reconnect to the material at the end.
    Only time I do not use proxies is for the 10-bit 4:2:2 modes (50 and 160Mbps flavors).
  • Ben Lewis
    July 19, 2016 at 6:29 am
    Hi Gary,
    Thanks for getting back to me. No, we didn’t use this feature. We shot at 10 bit 4:2:2 but the bit rate was 410 Mbps I believe.
    Is the proxy feature where you can record onto sd cards?
    I’ve been checking the footage in premier and noticed some lag but I now think this may be the fact I’m running from a usb 3 – 5200rpm drive.
    One thing both my DOP and I found interesting is the fact you have to change the cameras system frequency to be able to shoot at 24fps.
  • Gary Huff
    July 19, 2016 at 10:02 pm
    [Ben Lewis] “Is the proxy feature where you can record onto sd cards? “
    Yes, it records low bitrate 8-bit 4:2:0 footage for you to edit with.
  • Randy Larcombe
    June 22, 2017 at 12:31 pm
    Hi, How do you edit with the proxies and the relink to the hi res files? The proxy files have a P after them which stops the files from relinking at least in Resolve anyway.
  • Ben Lewis
    June 22, 2017 at 12:56 pm
    Hi, what software are you using to edit? What drives are you using and how are they connected?
