Activity Forums Apple Final Cut Pro C300 import?
  • C300 import?
    Posted by Bret Williams on August 16, 2014 at 5:18 am
    I’ve installed the plugin and the utility but still I can’t see c300 footage in the import window. I can see it just fine in the canon utility. I have a hard drive from the client. On the drive is a folder with the name of the shoot, and within that a contents folder. I I drag the whole folder to the event, it says there’s nothing it can recognize or import. If I access the folder from the import window it thinks for a quick second and then it’s blank. Am I missing something?
    Here’s a shot of the folder –
    Dan Hodlick replied 12 years, 1 month ago 3 Members · 3 Replies
  • Bret Williams
    August 16, 2014 at 6:10 am
    Nevermind it’s working. But still can’t get filmstrip mode.
  • Bob Woodhead
    August 16, 2014 at 11:51 am
    I use C300/100 footage every day for last couple years. Never had a problem using the Canon plugin. Just popped over to the Canon download page, and I see there’s a (much) newer import plugin available (as of 6/26/14). If you just downloaded, perhaps a bug in the new version? Maybe Canon can send you an old version to test.
  • Dan Hodlick
    August 20, 2014 at 1:18 pm
    Just to bounce this back to the top – FCPX will not import C300 footage at all. I’ve downloaded and installed the latest drivers and plugins – no joy.
    Works fine in premiere pro on the same computer
