Activity Forums Avid Media Composer C300 files AMA import into MC 6
  • C300 files AMA import into MC 6
    Posted by David Lewis on September 15, 2013 at 2:29 pm
    I’ve just returned from shooting with a C300 and have the files all downloaded and backed up.
    I have downloaded and imported the AMA for MFX and the recommended
    AMA plug-in for the Canon C300 to my computer. Now when trying to import the files into my MC6 (1080i 50fps)project I open up the Link to AMA Volume and it recognizes the file, but it won’t allow me to open up more than one file ( I have to double click down into the file containing the actual shot and data”… CONTENT, then the CLIPS001 file down to each individual take (i.e. AA0091; AA0092 etc.).
    With other footage shot on the C100 in AVCHD, I was able to easily open the footage to begin working with it. From the AVCHD file MC 6 easily opened and played the clips.
    No doubt I must be missing a step or a plug-in or a command to get this same ease of access. I CAN go and open each individual file, find the MXF clip and link it… but this will take a VERY long time. Must be a quicker way.
    Any suggestions?
    David C. Lewis
    Editor- Director
    DCL Video Productions
    Michael Phillips replied 13 years ago 3 Members · 4 Replies
  • Shane Ross
    September 15, 2013 at 7:46 pm
    Download and install all the AMA plugins. I found when I only installed the one for C300 it did this. But all of them, and it worked.
    Shane
    Little Frog Post
  • David Lewis
    September 15, 2013 at 8:36 pm
    Thank you Shane.
    I will give it a try… as they say “it couldn’t hurt”.
    David C. Lewis
    Editor- Director
  • David Lewis
    September 16, 2013 at 7:46 am
    Shane:
    Just spent a few minutes downloading most/all the AMAs (except Arri… which required a registered user), and as usual your suggestion worked perfectly.
    I appreciate the help. Nice when things work out as they should!
    All the best,
    David C. Lewis
    Editor- Director
  • Michael Phillips
    September 16, 2013 at 1:37 pm
    For Arri, you just need to create an account – a bit of a pain, but works.
    Michael
