Activity Forums Cinematography C100 – HDMI vs HDSDI
  • C100 – HDMI vs HDSDI
    Posted by Jason Brown on April 15, 2014 at 3:45 pm
    I’m going to push out HD feed to record on external ProRes recorder.
    Is there a quality difference in what I get from a traditional HD-SDI vs the HDMI feed from the C100?
    Malcolm Matusky replied 12 years, 4 months ago 2 Members · 1 Reply
  • Malcolm Matusky
    April 16, 2014 at 10:53 pm
    The C100 ONLY has HDMI output, you don’t have a choice. 8 bit. Mine works fine with the Ninja 2, but Canon has a “locking” HDMI port (screw terminal) the Ninja does not, so I have “perfect path” cables which are friction locked, better that the standard cables, but I would prefer a screw mount solution.
    M
    Malcolm
    http://www.malcolmproductions.com
