Activity Forums Apple Final Cut Pro Legacy Bypassing the Time Code in the Capture window
  • Bypassing the Time Code in the Capture window
    Posted by Pedro Casais on May 12, 2009 at 3:19 am
    I’m trying to capture a tape that has bad Time Code and in the Log and Capture window (FCP 6.1) there’re no options where you can select to capture or not the channels, either video, audio or Time code.
    I have a dv player hooked through firewire and the FCP software just grabs the video channel, audio and time code autimatically. Can I bypass the time code within the FCP software and if so where?
    Thank you.
    PC
    Rafael Amador replied 17 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    May 12, 2009 at 3:28 am
    Try “Capture Now”.
    rafael
    http://www.nagavideo.com
  • Pedro Casais
    May 12, 2009 at 3:45 am
    That’s how I am capturing the clips, but what I need to find out is how to capture them the way I’m doing it now but without the time code embedded on the clip, since it breaks every five minutes and aborts the process.
    best,
    P
  • Rafael Amador
    May 12, 2009 at 3:57 am
    Hola Pedro,
    FC abort the capture even with Capture Now?
    if so, you need to change your Preferences.
    Uncheck “Abort capture on dropped frames”.
    Set “On TC break: Wrn After capture”.
    Uncheck “Warn when importing non-optimized media”.
    Rafael
  • Rafael Amador
    Hola Pedro,
    Rafael
  • Pedro Casais
    May 12, 2009 at 4:06 am
    Gracias Rafael,
    That will probably do it.
    Best,
    PC
  • Russell Lasson
    May 12, 2009 at 5:00 am
    You should also try changing device control to non-controllable device.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Universal Post
    Salt Lake City, UT
  • Pedro Casais
    May 12, 2009 at 5:08 am
    Thanks Russ, where do I switch that option on the FCP software?
    best,
    PC
  • Rafael Amador
    May 12, 2009 at 7:41 am
    In Audio/Video Setting> Device Control.
    rafael
