Activity Forums DaVinci Resolve Bypass Output LUT
  • Bypass Output LUT
    Posted by Daniel Christie on July 11, 2014 at 12:57 pm
    Is it possible to bypass the output LUT on a per clip basis? I’m working on a project that is primarily S-Log3, so I’m using an S-Log3 to Rec709 output LUT but have a few assets (titles etc) that are not log.
    If I were working in ACES, I could do this with an inverse IDT.
    Cheers,
    Daniel
    John Sellars replied 12 years, 1 month ago 3 Members · 2 Replies
  • Eric Johnson
    July 11, 2014 at 6:23 pm
    I think the only way to do that would be to add the LUT at the end of each Node tree… and disable the Output LUT…
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • John Sellars
    July 13, 2014 at 5:59 pm
    What about adding the LUT to a track node, then turn it off with a static mark?
