Activity Forums DaVinci Resolve B/W render
  • B/W render
    Posted by Bristol Cruz on November 2, 2012 at 12:46 pm
    Hi!
    I work on a black/white project with hard contrast and with a lot of channel mixer adjustments.
    This is mainly for TV, but I also want to make a web master.
    Im adjusting internally full range (0-1023), my monitor is set up as 709 and Im monitoring in normal range. This makes the commercials look like it should on my monitor and for TV.
    Usually I render full range (RGB) for web versions but I see that the blacks will be super deep as the tonal range is a bit deeper on this project. The black between 0 – 40 IRE will be merged in a way.
    How do you deal with this? I can render 709 and do a black restoration in Sorenson but Im not sure if that is the best approach.
    BC
    Bristol Cruz replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
