Activity › Forums › Apple Final Cut Pro Legacy › buying new system!
  • buying new system!
    Posted by Niti Shah on June 20, 2005 at 4:23 am
    hi
    I am planning to buy new system for my small setup. My config is G5 2.7DP, FCP 4.5, Decklink Extreme, SCSI storage with ATTO 4D. i need advice from all of u on this. My most of the work will be SD for time being. i was just wondering about Compatibility of Tiger and FCP 4.5 and Decklink. I just eager to know about FCP 5. All suggestions are welcome.
    regards
    nikei
    Mitchji replied 21 years, 3 months ago 3 Members · 2 Replies
  • Walter Biscardi
    June 20, 2005 at 12:01 pm
    Drop SCSI and go Fibre Channel. Apple hasn’t supported SCSI for OS X and it’s up to the card / drive manufacturers to make it work. (notice Apple doesn’t sell a SCSI card or SCSI drives?)
    I prefer the AJA Kona 2 for a capture card though the Aurora Pipe series is a close second.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Mitchji
    June 20, 2005 at 3:02 pm
    [walter biscardi] “Drop SCSI and go Fibre Channel. Apple hasn’t supported SCSI for OS X and it’s up to the card / drive manufacturers to make it work. (notice Apple doesn’t sell a SCSI card or SCSI drives?) “
    The Medea Fibre Channel Video Raid reviewed here supports SCSCI Drives so you could migrate to Fibre Channel and use your SCSI drives:
    https://www.barefeats.com/hard47.html
    You might also want to check his benchmarks. A cheap SATA array is just as fast.
    Best Wishes,
    Mitch
