Activity Forums Blackmagic Design Buying Advice
  • Buying Advice
    Posted by Luiggi Berrios on February 29, 2008 at 9:18 pm
    I have a G4 dual 1.42ghz machine with 2 gig of RAM, Leopard 10.5.11, FCS 2 and I’m ready to buy an new converter since the old DA MAX doesn’t do HD. Wich coverter is the best for me to buy the Blackmagic Design Multibridge Pro or the AJA IO, I mostly do SD projects but this will change soon since I already do a couple of HD proyects. Please let me know which converter is the one I should buy.
    Kristian Lam replied 18 years, 6 months ago 3 Members · 2 Replies
  • Del Chapple
    March 3, 2008 at 8:14 pm
    the aja is Firewire 800 and does prorez only, which is fairly processor intensive, your g4 may not be fast enough even if it had the FW800 ports.
    del
    you cant hear my inner voice scream… can you..?
  • Kristian Lam
    March 3, 2008 at 11:21 pm
    You’ll really need a G5 or better machine to do HD. The Multibridge Pro will not run on your G4 as the G4 does not have PCI Express slots. The PCI slots simply does not have the bandwidth for HD video.
    regards
    Kristian Lam
    Blackmagic Design
