Activity › Forums › Adobe Premiere Pro › Buying a new monitor for color accuracy
Posted by Manish Choudhary on February 13, 2018 at 10:24 amPlease help buying a new monitor for color accuracy
after a lot of search i find benq had “Technicolor Certified” monitors for color accuracy but i am confused which one to buy
both are under my budget but main thing is color accuracy in my Music videos.
please help
Links Below :-
https://www.benq.com/en-us/monitor/photographer/sw320.html
https://www.benq.com/en-us/monitor/video-post-production/pv3200pt.html
Manish Choudhary replied 8 years, 6 months ago 6 Members · 36 Replies -
Kevin Rag
February 13, 2018 at 1:01 pmFor Color grading? Get a Flanders Scientific. Real good broadcast monitors.
K
Manish Choudhary
February 13, 2018 at 3:25 pmi have my budget under 1500$ thats why i am looking at benq
Brent Marginet
February 13, 2018 at 5:30 pmBenq makes computer monitors and computer monitors are not acurrate in any way shape or form. They’re also fed by DVI, HDMI or Display Ports from your video card which is not accurate as well. It needs to be HDSDI from a proper output box or card which will set you back a bit if coin as well. If you want an acurrate monitor for color correction your going to have to spend at least double that. Reality is that you will be in the range of $4000 to $7000 US.
Don’t waste $1500 on something that’s not going to be much more accurate than what you already have.
\”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more.
Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\” -
Manish Choudhary
February 13, 2018 at 6:11 pmthanx but i need one for my workflow so what you think which one i should buy for my work until i have 4 to 7000$ USD
coz i need one i asked for these monitor coz they are color accuracy certified via “Technicolor”or should i buy one from dell or anything under 1000$ ?
Shane Ross
February 13, 2018 at 6:15 pmThat monitor might work, but you’ll need a video IO device between your computer and it for accuracy…something from Blackmagic Design or AJA. And it being a computer display, it will only deal with progressive video, not interlaced.
And you’ll need to calibrate it to bars, or have someone do it, so you know it’s accurate for video. But yes, you’ll need a video IO between your computer and it.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Manish Choudhary
February 13, 2018 at 6:19 pm@Shane i think u talking about x-rite or some other device for color calibration
and something from blackmagic and aja like sdi card?
Shane Ross
February 13, 2018 at 6:29 pm[manish choudhary] ” i think u talking about x-rite or some other device for color calibration”
Those are to balance computer displays for PHOTOGRAPHY, not video. I’m not sure what to use for video when you have a computer display. I have a Flanders monitor, and that is calibrated differently. Wish I could offer advice on this.
[manish choudhary] “and something from blackmagic and aja like sdi card?”
Well, what computer do you have? There’s the UltraStudio series from BlackMagic for computers with Thunderbolt 2 connections. There’s the INTENSITY for computers with PCIe slots, and even options for USB3 connections. AJA offers internal PCIe cards and Thunderbolt options.
Shane
Little Frog Post
Manish Choudhary
February 13, 2018 at 6:35 pmi have dell’s workstation series tower 5820
system config is :-processor – intel xeon w-2175 14 core
ram – 64 gb 2666 mhz ddr4
graphic card – nvidia quadro p5000 16gb ddr5 memory
thunderbolt 3 pcie card – 1
i need monitor for video editing not for photo editing and monitors i mentioned above are factory calibrated for rec 709, adobe rgb, srgb, dci-p3.
Manish Choudhary
February 13, 2018 at 6:37 pmblackmagic’s ultra studio device with thunderbolt 2 and also macbook pro late 2015 with thunderbolt 2
Brent Marginet
February 13, 2018 at 7:34 pmDown to the nuts and bolts of things. No matter what kind of output device is used, HDMI is not truly broadcast accurate and the monitors are not truly Rec-709 Accurate. Subtleties in the most important places like the Blacks, Gamma, Whites, Colour Temperature and overall Colour can easily lead you astray with a computer monitor.
