Activity › Forums › Apple Final Cut Pro Legacy › Buying a MacPro … Should I get More CPU or More RAM?
  • Buying a MacPro … Should I get More CPU or More RAM?
    Posted by Cory Mckechnie on August 31, 2007 at 11:18 pm
    Hello Cow Commoonity, quick question for everyone.
    I am purchasing a MacPro (on a mostly fixed budget) and am debating which to get. Option A – Two 3.0GHz with 4GB RAM or Option B – Two 2.66GHz with 8GB RAM. Any thoughts? The difference is about $250 more if I go with 8GB of RAM.
    I ask in this forum as I’m specifically interested in Final Cut and Motion’s wants … will a higher CPU be more beneficial for these programs or the extra RAM? I was kind of leaning to the RAM, but they are 8x1GB sticks so easily increasing down the road wouldn’t be possible.
    Any thoughts, articles, benchmarks, opinions that could be offered would be greatly appreciated.
    As always, thanks in advance!!
    Cory
    Cory Mckechnie replied 19 years ago 5 Members · 6 Replies
  • Dan Riley
    September 1, 2007 at 12:26 am
    More RAM is better, but I have a question for you….
    Are you getting the RAM from Apple in the config you mentioned?
    Because if you are, you are paying twice as much as you need to
    for 8 gigs of RAM. Don’t do that. Buy great RAM from transintl.com
    or macsales.com Maybe if you do this, you can get both the QUAD 3 gig
    and the RAM. Even so, my advice is get as much RAM as you can.
    8 gigs is good. 4 gigs, not so much. The problem is you computer
    will use it’s virtual RAM feature (meaning it uses your system hard drive
    as fake RAM) much more often. This is obviously slower than RAM.
    You can’t turn this off in OSX, so the only thing you can do is
    purchase more RAM if you are going to be using apps that like to use
    RAM to operate, like Motion, FCP, Photoshop, After Effects, etc.
    Just one man’s opinion. Let’s see who else chirps up.
    Dan
  • David Roth weiss
    September 1, 2007 at 2:28 am
    Everything Dan said about RAM is true, my only disagreemnt with his reasoning is that, since procs are not really upgradable and since RAM is, you only get one shot at the procs…
    Okay, that being said, RAM is more important than ever before now, and it will become even more imnportant later when 64-bit FCP comes out. So…
    And, don’t forget hard drive speed/throughput. Striping four SATA drives together in that MacPro and using the other Superdrive space for your system drive will get you bucket loads of performance too, many, many times faster than firewire 800. So don’t skimp there either…
    Now, where did you say you found that money tree??? I need to find one myself.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Rj Miles
    September 2, 2007 at 6:04 am
    Unless something changes, it will be easier to add more memory than increase the processor speed. So, I would get the fastest Mac Pro, and add more ram when I could afford.
    Based on some early hacking of the 8-core processor on quad Mac Pros, I thought there might be a future for swapping in faster processors as they became affordable, but that possibly hasn’t materialize yet.
    We have now bought 16GB of ram from OWC for our Mac Pro 8-core machines, and but for (1) 2GB stick OWC advance replaced, their cheap ram has been flawless. (knock on wood)
    Happy shopping
    PS… I bought MY 8-core as an Apple Refurb and it came with the X1900 card instead of the 7300GT listed on the Apple website. 🙂
  • Cory Mckechnie
    September 2, 2007 at 10:08 pm
    Thanks everyone for the help. I was completely unaware of the 3rd party RAM options. I will definitely be getting the dual 3GHz procs and picking up 8GB of RAM from either macsales.com or transintl.com!! Once I get a little closer to clicking the send button on this purchase (in the next couple weeks) I’ll probably be back with more specific questions about the RAM and if there’s a difference between those two sites in terms of what RAM they sell, but until then I’m excited about my now even cooler new machine!!
    Thanks again,
    Cory
  • Walter Biscardi
    September 2, 2007 at 11:37 pm
    [Cory McKechnie] “I will definitely be getting the dual 3GHz procs and picking up 8GB of RAM from either macsales.com or transintl.com!!”
    I only recommend Crucial.com. they seem to have the best quality and most reliable RAM of anyone out there. From what I understand, it’s the exact same RAM that Apple installs.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Cory Mckechnie
    September 3, 2007 at 1:52 pm
    Interesting, I’ll keep that in mind when buying the RAM.
    Thanks Walter,
    Cory
