Activity › Forums › Adobe Encore DVD › buttons not working after building
Posted by Seth Low on May 12, 2009 at 4:51 pmHey All,
I am currently making my showreel on encore cs3. Basic layout of a main and multiple videos. No chapters. I laid everything out and hit preview and all the video links and buttons works. The problem is after I build the disc, the buttons stops working. As in it’s not selectable/highlightable and I can’t click on anything. My main is just a static image. Is there anything I missed along the way? I’m just curious, if in the preview, everything works fine… why isn’t the final build okay? Please help. Thanks.
Paul Benson replied 17 years, 3 months ago 4 Members · 8 Replies -
Joe Bowden
May 13, 2009 at 12:58 amHave you checked your button routing? Is it as you expect it to be?
Seth Low
May 13, 2009 at 2:31 amat the moment, after rechecking, there’s a few links not pointing to the right clip. nothing too serious for me but would that be the cause of my problem? because i tried navigating in the preview and it works fine. i can select any clip i want, play it and it will pop back onto the main. it’s just frustrating that when the preview shows everything is okay but when you build the disc, the main is just a single static frame. and i can’t move to select/highlight a clip to play.
just wondering, would having 17 clips on a single main be a problem? i’m just trying to lay out my reel onto a single main so that my potential employers/clients don’t have to navigate into chapter/subs.
Jeff Bellune
May 13, 2009 at 12:25 pm[Seth Low] “when you build the disc, the main is just a single static frame”
Are you talking about the Main Menu, or the main video of your reel? What is your desired behavior, specifically?
[Seth Low] “would having 17 clips on a single main be a problem?”
How many buttons (total) are on the menu? For a widescreen DVD, 18 total buttons is the limit.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Joe Bowden
May 13, 2009 at 5:11 pmButton routing is where you set each of the arrow keys on the remote control to take you to another button in the menu. This should not be confused with button linking. Do a search on “button routing” in Encore’s help.
I don’t see any obvious problem with your timeline situation.
Paul Benson
May 15, 2009 at 4:49 amIf you run your DVD on a computer, do the links work with a mouse? Do the links work if you use the virtual navigation buttons?
If you run your DVD on a DVD player, do the links work with the navigation buttons?
Just trying to understand the issue a bit more.
Pauley
Seth Low
May 17, 2009 at 2:12 pmButton routing is where you set each of the arrow keys on the remote control to take you to another button in the menu. This should not be confused with button linking. Do a search on “button routing” in Encore’s help.
yea joe, i recheck and relinked the button routing. i understand how that works =)
pauley, nope. the buttons doesn’t seem to work at all. but during preview mode it worked fine. as in i could navigate with the mouse. the links all work and pointed to the correct movie.
Jeff Bellune
May 17, 2009 at 2:19 pmAre you on a Mac?
If so, edit the menu in Photoshop and change the name of all of the (=1) highlight layers to (=2) and test again. Preferably using an RW disc.
-Jeff
Paul Benson
May 18, 2009 at 7:13 pmI have fortunately not encountered this. Here are some things I would try to work around this (assuming it is too much work to restart).
Change the loop point. Assuming it is at 0 right now, make it 00:00:01 to see what happens. Maybe that will ‘kick start’ the buttons.
Copy and paste the menu and use the second one.
If the above doesn’t work, then have your first one auto-activate to the second one.
Have a dummy black 1 second menu screen as your first menu which times out after 1 iteration to your next menu screen.
Pauley
