Activity Forums Adobe Encore DVD Button Transitions question
  • Button Transitions question
    Posted by Gene Colburn — email address bounces notices on July 4, 2006 at 4:35 am
    Can someone tell me what the function options of this are supposed to be? You would think that an Encore help search would find info about a Tabbed property function, but nothing found. I am sure it relates to an annimated button action, but going to the Buttons property tab that shows this function calls up no action that I can see. I was hoping it would allow some button fades with cursor over menu areas. Just not sure, and no can find info.
    David Garrett replied 20 years, 2 months ago 2 Members · 5 Replies
  • David Garrett
    July 5, 2006 at 11:55 am
    what it means is that you can link your button to play a timeline clip and then use the “Button Transistion” option to play a small .avi file of your choosing which in turn will then play the choosen video file that the button was orginally linked to……
  • Thanks Dave
    I need to investigate this further as it sounds like it could be useful.
  • David Garrett
    July 7, 2006 at 10:58 am
    this should help you a little bit more.. just a brief tutorial on the transistion function of Encore (https://asvideoproductions.com/doogs/encore2%20tut002.zip)
  • Thanks David
    Kinda slick. I was assuming it could be used with sound effects, but picture worth thousand words.
  • David Garrett
    July 8, 2006 at 9:54 am
    you could just use a copy of the menu and then add some audio or soundFX to this in your video editor and then export as .avi
