Activity Forums Adobe Encore DVD button selection problem
  • button selection problem
    Posted by Phil Biggs on January 4, 2006 at 11:58 am
    Hi there,
    I’m having a problem with button selection. My buttons are text layers done in Photoshop – all layers and layer sets are named with the correct protocol.
    When I preview my menu in Encore, all the buttons (14 in a vertical column) can be selected and activated with the mouse. However, when using the remote down key, two buttons (8 and 10) are skipped over. These two buttons contain four words, the others two, and are therefore wider in terms of pixels. Does this have something to do with it or is that just coincidence? Is there a limit to the width of a button? If so, how can I select them with the mouse but not the remote?
    Hope this makes sense.
    Many thanks,
    Phil
    Dominic Osborne replied 20 years, 8 months ago 3 Members · 2 Replies
  • David Garrett
    January 4, 2006 at 2:19 pm
    sounds like the buttons are overlapping? check the button routing to check that there is enough space between the buttons and their respective bounding box
  • Dominic Osborne
    January 12, 2006 at 6:12 pm
    yes, check if their bounding boxes are over-lapping, but also check the routing of the buttons – if Encore ahs done it for you automagically, it may have had a hiccup in its process.
