Activity Forums Adobe Encore DVD Button Routing Problem
  • Button Routing Problem
    Posted by Joel Vanz on November 17, 2010 at 1:08 am
    I’m having problems routing my buttons in my scene selection menu. I am able to change the middle number of each router but I am not able to change the left, right, up or down numbers. Anyone know how to do this?
    Joel
    Joel Vanz replied 15 years, 10 months ago 2 Members · 3 Replies
  • Ricky Barrow
    November 17, 2010 at 1:19 pm
    If your photoshop menu is layered and you want the upper most button (visually) to be button “1” then that should be the bottom layer set in PS – Encore by default starts button numbers from the bottom up – this may save you time in renumbering the buttons themselves. To manually route buttons you must deselect (it is checked or selected by default) the “automatically route buttons” selection – sorry, I forgot exactly where this is …. when the menu is selected it may be in the properties window. Then simply click and drag one of the navigational arrows and release it when over the position you want it routed to.
    Ricky
  • Joel Vanz
    November 17, 2010 at 9:42 pm
    right. I had unchecked the “automatically route buttons” button. But when I put my cursor over the left, right, up and down buttons to reroute them the only thing it gives me is a hand tool and I cannot change the routing. Even in the properties window, there is nothing I can see to reroute left, right, up and down for each button…. 🙁
  • Joel Vanz
    November 17, 2010 at 10:08 pm
