Activity Forums Adobe Encore DVD Button Poster Frame: Error Message
  • Button Poster Frame: Error Message
    Posted by Melvin Royster on September 29, 2005 at 9:54 pm
    Hey all, I was trying to create a moving poster frame for my menu. I couldn’t just have the timeline marker over the starting point of the poster frame, and set use Timeline>Set Poster Frame. The option wasn’t highlighted to select. So I set a chapter point in the timeline, then tried to Left Click>Set Poster Frame, and it seemed like it changed the poster frame, but it was still blank.
    So I thought I had to render it first, after I set the motion length in the properties menu, but it started to render then an error message popped up saying: “Sorry abnormal condition has been detected. Before quitting, you have one chance to save your project (don’t use the same name as the original).” And I couldn’t even burn the DVD to test it out and see if it went through.
    What should I do? I tried this many times, and still nothing, even recreated the entire project, still nothing. The menu was edited in Photoshop, where I changed the background, erased a couple of buttons, and renamed a couple of things. Can anyone help? Thanks.
    Melvin Royster
    PC
    Encore 1.5
    Photoshop CS
    1.0 Gig RAM
    Melvin Royster replied 20 years, 11 months ago 2 Members · 2 Replies
  • Joe Bowden
    September 29, 2005 at 10:16 pm
    Try saving the menu as a Photoshop file, then delete the menu form your project, import the PSD you saved as menu, then re-linking.
    Does that help?
  • Melvin Royster
    September 30, 2005 at 7:38 am
    Nope it didn’t work, I tried that already too. But I thought I was getting somewhere last night, I linked the last two menu buttons, animated them, saved it and rendered it. They worked fine. It animated the buttons just the way I wanted it. But when I tried to link the 1st button, and animated it, then tried to render, that’s when the error message occurred. I can animte and render the last two buttons but not the first.
    Can anyone help?
    Melvin
    PC
    Encore 1.5
    Photoshop CS
    1.0 RAM
