Activity Forums Adobe Encore DVD button highlights disappear
  • button highlights disappear
    Posted by John Kis on June 22, 2009 at 1:07 am
    Hello all,
    I have a static menu with an audio background. After the audio finishes, my button highlights disappear. I also can’t select anything, so the function disappears aswell. Any idea on this one?!
    John
    John Kis replied 17 years, 2 months ago 2 Members · 6 Replies
  • Joe Bowden
    June 22, 2009 at 1:43 am
    Which version of Encore, and Mac or Windows?
    Also, what’s the duration & loop point timecodes for the motion menu? (you can find this in Menu properties)
  • John Kis
    June 22, 2009 at 1:58 am
    Hi Joe,
    I’m using CS4 for windows.
    The duration for the audio track is 9 seconds, however i have entered 10 minutes into the duration field. The highlights disappear after 9 seconds.
    The loop point is 00:00.
    I have loop # set to None.
  • Joe Bowden
    June 22, 2009 at 3:42 am
    Is this happening only in Encore Preview mode, or have you seen this behavior on a burned DVD?
  • John Kis
    June 22, 2009 at 3:45 am
    In a burned DVD.
  • Joe Bowden
    June 22, 2009 at 2:15 pm
    OK, so it seems it’s not just a preview issue.
    I’d reckon that if your asset duration matched your menu duration, you would not see this problem. You might want to try that as a workaround, if you’re looking for a quick solution.
    If you have a little more time to poke around, you might want to try a shorter menu duration – does the same thing happen if its duration is 15 seconds? If not, find out how far you can push it before the problem shows itself.
  • John Kis
    June 22, 2009 at 9:55 pm
    Thanks Joe – great advice.
