Activity Forums Adobe Encore DVD Button Help
  • Button Help
    Posted by Matthew Press on August 10, 2005 at 4:01 pm
    Hi Guys,
    I’m making 3 Buttons using live footage in each. Very simple.
    My problen is the footage only plays for 15 seconds in the Button Frames no matter what duration I give the menu. Actually if I give the Menu a 30 Sec. duration the footage freezes at 15 sec. till it reaches the 30 sec duration and then loops back. How do I get the Whole film to play in the Buttons?
    Matt
    Matthew Press replied 21 years, 1 month ago 2 Members · 3 Replies
  • Joe Bowden
    August 10, 2005 at 4:10 pm
    Try this: create a video background (it could be just a static menu background – turn off ‘Optimize Stills’ if you’re using PPro) that is the length of the duration you want. Or it could be a silent audio track, just make it the duration you want.
    Render motion menus and you should get what you are looking for.
  • Matthew Press
    August 10, 2005 at 4:31 pm
    Joe I’m not sure how this helps the duration of video playing as a Button.
  • Matthew Press
    August 10, 2005 at 4:48 pm
    Joe I tried the Audio Trk under the Menu trick and that worked perfectly.
    Thanks for your help.
    Matt
