Activity › Forums › Adobe After Effects Expressions › “Butt Cap” to “Round Cap” with a Script (But it doesn’t work)
  • “Butt Cap” to “Round Cap” with a Script (But it doesn’t work)
    Posted by Vincenzo Imbimbo on January 31, 2022 at 3:31 pm
    Hi guys! I don’t know what i’m doing wrong, this should be working, anyone can help me?
    I’m trying to change the “Butt Cap” of selected shape layers to “Round Cap” but i can’t figure it out why is not working, here is the code:
    var project = app.project;
    var comp = project.activeItem;
    app.beginUndoGroup("Process");
    var myLayers = comp.selectedLayers;
    var myLayer;
    for (var i = 0; i < myLayers.length; i++){
    myLayer = myLayers[i];
    if (myLayer instanceof ShapeLayer){
    var myContents = myLayer.property("ADBE Root Vectors Group");
    for (var j = 1; j <= myContents.numProperties; j++){
    myContents.property(j).property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Shape - Group").property("ADBE Vector Shape").property("ADBE Vector Graphic - Stroke").property("ADBE Vector Stroke Line Cap").setValue(2);
    app.endUndoGroup();
    Filip Vandueren replied 4 years, 7 months ago 2 Members · 2 Replies
  • Vincenzo Imbimbo
    January 31, 2022 at 5:37 pm
    I make it work but only for 1 shape element of each shape layer, i want it to work in any shape layer no matter how much elements it has inside the Groups.
    This is what it works:
    var myContents = myLayers[i].property("ADBE Root Vectors Group").property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Graphic - Stroke").property("ADBE Vector Stroke Line Cap").setValue(2);
    app.endUndoGroup();
    And this is what i’m doing trying to work through all the properties (i want it to work in any scenario):
    var myContents = myLayers[i].property("ADBE Root Vectors Group");
    myContents.property(j).property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Graphic - Stroke").property("ADBE Vector Stroke Line Cap").setValue(2);
    app.endUndoGroup();
  • Filip Vandueren
    February 2, 2022 at 2:33 pm
    Hi Vincenzo,
    since you can’t be sure of the exact “path” to the Line Cap property (it can be embedded into a shapegroup, there could be multiple paths/shapes/rectangels etc, each with multiple strokes…) I think you need to go through each property recursively and if it’s the right one, apply the value.
    Something like this:
    tryLineCap(myLayers[i].property("ADBE Root Vectors Group"))
    function tryLineCap(prop) {
    for (var j = 1; j <= prop.numProperties; j++){
    var subProp = prop.property(j);
    if (subProp.numProperties) {
    tryLineCap(subProp)
    } else {
    if (subProp.matchName == "ADBE Vector Stroke Line Cap") {
    subProp.setValue(2);
    app.endUndoGroup();
