Activity Forums Adobe After Effects Bursting through background
  • Bursting through background
    Posted by Tei Jackson on February 10, 2011 at 9:32 pm
    Will someone please tell me how to create an animation where an object bursts through the background leaving a tear. I would like to create a small introduction with a logo bursting through paper (the background). Lastly, I would like this to be 3D. Is it better to make the images 3D in Illustrator using “Bevel and extrude” or is it better to do it in After Effects using “Shatter”?
    Thank you all so much for your time!
    Tei Jackson replied 15 years, 7 months ago 2 Members · 2 Replies
  • Graham Macfarlane
    February 11, 2011 at 9:59 am
    To create a proper 3D tearing effect you would need to go down the route of soft body dynamics in a serious 3D application however there should be a way of cheating it in AE.
    I have done this very effect many years ago before 3D existed in AE and back then I simply filmed real ripped paper against black and composited it into my work.
    If not using a 3D app or filming real paper tears you might want to have a look at all the distortion effects that AE has to offer and design your tearing effect within Photoshop with reference photography to build up a PSD file full of layers containing torn edges that can be manipulated and distorted in AE to create the animated tear you desire!
    I’m not sure how Illustrator’s bevelling or extruding can create 3D-ness in AE which compares to the shatter effect however it might be possible to use shatter with some carefully made shatter maps and the right motion for the bits which fly off to achieve some sort of ripped hole appearing in a layer.
    To flex or bend the layer like paper would if being punched through might be achievable with Invigorator or freeform (which comes with AE CS5. see: https://digieffects.com/product/freeform_ae)
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
  • Tei Jackson
    February 11, 2011 at 5:06 pm
    Thank you, Graham! I will play around with your suggestions over the next few days to see what I can come up with.
