Activity Forums Adobe After Effects burst like soap bubble
  • burst like soap bubble
    Posted by Fran Zine on March 9, 2010 at 12:43 pm
    Hi does anybody know if there is an effect in after effects, that could let burst a video like a soap bubble?
    i have two little videos, and as final i would like to let these two videos like a soap bubble.
    for any help deeply thankful.
    greets from germany
    Bill Kelly replied 16 years, 6 months ago 3 Members · 2 Replies
  • Michael Szalapski
    March 9, 2010 at 3:55 pm
    Unless you’re talking about slow motion, a real soap bubble basically just disappears. There will be a few little soap particles, but it really just goes POP and is gone.
    However, I assume you mean you want it to blow up and disappear outwards. You could use a distort effect, such as Bulge. Coupled with Effect>Transition>Iris Wipe.
    You’ll need to adjust the parameters of the iris wipe to make it look round (make iris points a higher number), then feather it.
    Assuming I assumed the effect you were after correctly, that should do the trick.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Bill Kelly
    March 9, 2010 at 10:32 pm
    The Scatterize effect may also work for your situation. To make it look good, you would most likely want to introduce a blur on the scatterizing (is that really a word) layer as the scatterizing is taking place, and enable motion blur for the layer and the comp.
