Activity › Forums › VEGAS Pro › Burning to widescreen
  • Burning to widescreen
    Posted by Jay Salinas on April 7, 2011 at 6:30 pm
    I have a question about how I can burn my DVD to widescreen on Sony Vegas using DVD Architect? Must I render it to widescreen and then it will burn widescreen or what? I’ve been burning all of my projects to 4:3 but feel like I should probably switch to widescreen with everyone getting LCD, Plasma, LED, etc. I did burn my HD content to DVD and played it on my PS3 and it automatically came out widescreen. However, I burned the same project to DVD and it came out 4:3. Thanks for the help!
    Yeah!!!
    Nigel O’neill replied 15 years, 5 months ago 3 Members · 2 Replies
  • Mike Kujbida
    April 7, 2011 at 6:53 pm
    Make sure your Vegas Project Properties are set to NTSC (or PAL) DV Widescreen (720×480, 29.970 fps).
    When you’re done, render to MPEG-2 using the DVD Architect NTSC (or PAL) Widescreen video stream preset.
    In DVDA, change your properties from 4:3 to 16:9.
    That’s all there is to it.
  • Nigel O’neill
    April 8, 2011 at 3:54 am
    Jay, what is your source footage? You don’t want to end up stretching or cropping footage, which typically happens when going from a 4:3 source to 16:9.
    Ideally, your input source should match your output dimensionally.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
