Activity Forums Adobe After Effects Burning to DVD
  • Burning to DVD
    Posted by Avrohom Kohn on March 23, 2006 at 7:53 pm
    I created a movie that has photoshop graphics only, and want to burn to dvd. I tried rendering an uncompressed file, but the final DVD, when burned in iDVD, has artifacts. What is the best way to get a good-looking DVD through iDVD (which compression
    Axel Rogge replied 20 years, 6 months ago 4 Members · 6 Replies
  • Avrohom Kohn
    March 23, 2006 at 8:19 pm
    I now tried it with dv compression, but it came out very pixelated
  • Avrohom Kohn
    March 23, 2006 at 8:50 pm
    I just did a third test using AE’s default ‘lossless’ setting. The qt movie is beautiful, but when I bring it into iDVD it comes out soooo bad
  • Steve Morris
    March 23, 2006 at 9:44 pm
    What are the resolutions of the Photosop documents? Are there any fine lines in the pictures? I Is the QT video was at full resolution of 720 x 480? I don’t know iDVD, so I can’t help you there.
  • Avrohom Kohn
    March 23, 2006 at 10:26 pm
    The size of the video is 1024×576. There aren’t really any fine lines, the artifact is occuring to everything. The QT video is at full resolution.
  • Xtothed
    March 24, 2006 at 9:51 am
    This doesnt really help…but I have had a similar thing.
    I made a 30 commercial for television, which had a crawl along the bottom. This looked fine in AE and also when I imported it into FCP. But when I used compressor to make it m2v, or if I exported a self contained QT into iDVD or even DVDSP, there was huge glitching and/or fuzziness (as if the fields were out of sync) on the text that was crawling.
    When I dumped the animation to tape – for broadcast – it was fine, but when I burnt the animation to DVD for our clients to view I couldnt get rid of it, and I looked like an idiot and just had to assure them everything was fine.
    I never managed to sort the problem – if anyone knows how to help would be much appreciated.
    Xavier
  • Axel Rogge
    March 24, 2006 at 3:41 pm
    I
