Activity Forums Apple Final Cut Pro burning to DVD from FCPx
  • burning to DVD from FCPx
    Posted by Karen Ackerman on January 25, 2012 at 8:17 pm
    I have created a project in FCPx for an assignment for my masters.
    I need to hand in two DVDs. One playable on a DVD player and one quick time file.
    I have two problems – I can burn to DVD no problem from FCPx and it plays on the computer fine, but I have tried it on three DVD players – on one it won’t play at all
    On one it freezes on a section with captions over pictures – and doesn’t play it right
    On the third it jumps every few frames from widescreen to 16:9
    Any ideas?
    My .mov file is 5.7GB which means I can’t burn it to my DVD-R which only takes 4.7GB, then only bigger DVD I can get is DVD+R – I can burn to it, but it plays back all slow and weird….
    HELP, assignment due in Friday!!
    Karen Ackerman replied 14 years, 7 months ago 4 Members · 5 Replies
  • Loren Risker
    January 25, 2012 at 11:07 pm
    Here’s what I would do:
    Export a quicktime from FCPX, just use the timeline settings to get a raw video file.
    Compress that file using compressor and an h.264 setting. The auto youtube one will be fine. That will compress it enough to make your data DVD.
    Then use that quicktime to make your DVD-player DVD. What program are you using to burn it? Sounds like the data rate might be too high for older/cheaper DVD players. I prefer to use Toast with automatic settings for easy burning.
  • Karen Ackerman
    January 25, 2012 at 11:17 pm
    Thanks so much. I managed to get the DVD to work by burning it from IDVD with a quick time file instead of burning straight from FCPx. You’re probably right – FCPX was using too high a date rate.
    Now I’m a bit of a novice – how do I find compressor – is it automatically on the macbook pro or do I need to buy it? I haven’t used Toast – is that user friendly?
    help hugely appreciated
  • David Decker
    January 26, 2012 at 12:07 am
    For the sake of conversation, what about “share” to DVD from FCPX? Does this use the same compression as Compressor? Just curious.
    David Decker
  • Mark Morache
    January 26, 2012 at 5:24 am
    To export a compressed video from FCX try this.
    Share / Export Media (CMD E)
    Then under video settings, select h.264
    This should export a file the same frame size as your project, but compressed to a size that’s much more manageable.
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Karen Ackerman
    January 26, 2012 at 11:42 pm
    Brilliant – thanks Mark
