Activity › Forums › Apple Final Cut Pro Legacy › burning timecode
  • burning timecode
    Posted by Cheryl Cambras on August 1, 2007 at 9:31 pm
    Hi there,
    What’s the simplest/fastest way to burn timecode over an edited sequence in FCP? I need to pass it on to a sound designer. Is it possible to lay timecode without rendering?
    Cheryl
    Cheryl Cambras replied 19 years, 2 months ago 7 Members · 12 Replies
  • 12 Replies
  • Russell Lasson
    August 1, 2007 at 9:43 pm
    With Compressor 3 in FCS2 you can select to add a timecode window.
    In FCP5, I apply a title over the entire show (delete the text of the title) and then apply a time code filter to the title. You’ll need to manually change the duration of the title in the viewer window to make it long enough.
    From my experience, this takes less time to render than if you nest the sequence and apply the filter to it.
    Or you can make a master tape and then digitize it back in from the deck with the timecode burned in. (or just give the tape to the sound guy if he’ll accept it.)
    -Russ
  • Jeremy Garchow
    August 1, 2007 at 9:45 pm
    What version of FCP do you have?
    If you have FCS2, you can put a window burn on a qt movie when you compress it.
    If you have a Kona card, you can export the movie, play it through Kona TV and turn on the tc option in the control panel out to a deck/DVD recorder.
    Otherwise, use the tc generator filter and render.
    Jeremy
  • Shane Ross
    1) Nest the sequence. But in my experience that means re-rendering a lot of things. so I do…
    2) Export a self contained QT movie (or ref movie…faster) using the sequence settings, reimport that and drop it into a sequence, then add the filter. NO rendering.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Ben Holmes
    August 1, 2007 at 9:46 pm
    [cheryl201] “Is it possible to lay timecode without rendering?”
    No.
    Use the timecode generator filter. If you export the timeline as a clip, reimport and lay this clip into a new timeline, and apply just this single filter, it will speed things up a lot. You could even export the timeline in DV format (depending on what it is already) although the quicker TC render will be offset by an export time.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
    https://www.editecuk.com/OBServer2.html
  • Ben Holmes
    August 1, 2007 at 9:47 pm
    Blimey.
    In the time it took me to write that, you got about 4 answers. This forum is competitive.
    Ben
  • John Fishback
    August 1, 2007 at 9:49 pm
    There’s a timecode reader in Effects>Video Filters>Video. If you place it on a clip you’ll get the clip’s source timecode (probably not what you want). If you nest your sequence and put the reader on your nest, you’ll get the timeline’s code. No rendering is necessary, although, when you export the QT you might have rendering due to other effects, etc. If this is going to Pro Tools you need to send a DV QT.
    However, for the purpose of sound design, in addition to the video, you might also want to separately export your audio tracks as either an omf or aiff (with a 2-pop or other way of syncing the audio to the video). Ask you sound designer about that.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Russell Lasson
    August 1, 2007 at 9:56 pm
    It’s kind of like a radio show, “And the seventh person to submit a post on this thread will be the lucky winner of a free year subscription to the amazing Creative Cow Magazine!”
    My excuse is that I’m exporting a movie from FCP right now:) It got to about 85% and then FCP quit, so I had to start over. The cow is a nice way to pass those hours of waiting.
    What’s everyone else’s excuse for spending some much time on the cow?
    -Russ
  • Shane Ross
    August 1, 2007 at 10:01 pm
    [Russell Lasson] “What’s everyone else’s excuse for spending some much time on the cow?”
    Listening to music to figure out what I want to cut into this sequence.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    August 1, 2007 at 10:06 pm
    Waiting for the 3D guy to get me a goshD render so I can put it in the timeline and post for a client.
    Why can’t 3D be fast?
    Porche’s are fast and they are 3D. 😀
  • Russell Lasson
    August 1, 2007 at 10:12 pm
    So we’re all just a bunch of bored editors:)
    My export is back up to 78%. We’ll see if FCP kicks the bucket again. Ohhhh…. The excitement.
    -Russ
