Activity Forums Adobe Encore DVD burning problem
  • burning problem
    Posted by Mike Morris on April 6, 2005 at 8:36 pm
    Okay, this is the third time this has happened to me, and I can’t seem to figure out what the problem is. It only seems to happen on some projects, but not others. RIght now I am doing a project that is around 30 minutes long, and is a combination of video and image stills. I used premiere to encode it into mpeg-2 and imported it into Encore DVD. For some reason, when I imported it into Encore, it now fades to black after a certain point (roughly 3 minutes into the video). The image comes back in once the song changes, but then fades out again after a few seconds with the new song. What is the deal? is my problem in Encore or Premiere? Thanks.
    Sib Ntsib Dua
    Xeeb
    Roadkill replied 21 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Roadkill
    April 6, 2005 at 8:43 pm
    Xeeb,
    Is there a relation between the video going to black and the use of stills? If so, try exporting the video again from Premiere with the “Optimize Stills” export setting disabled.
  • Mike Morris
    April 6, 2005 at 10:24 pm
    is it possible that the field dominance might have something to do with it? I set it for Lower, and I am pretty sure Encore is defaulted to lower, but even the stills that do work look like garbage, so I am wondering if I have some field issues. I will try turning off the optimize stills setting.
    Sib Ntsib Dua
    Xeeb
  • Mike Morris
    April 8, 2005 at 12:02 am
    I figured out the problem… I need to buy a Mac with Final Cut and DVD studio pro.
    Sib Ntsib Dua
    Xeeb
  • Xena
    April 8, 2005 at 2:05 pm
    what if you try to export your premiere project as a movie then import the avi file into encore? if it plays that ok then let encore do the encoding.
  • Roadkill
    April 8, 2005 at 7:56 pm
    Nyob zoo Xeeb,
    In case you are thinking that everything that runs on a Mac runs without a hitch, I would suggest to take a peek at e.g. the Cow DVDSP and FCP forums.
  • Mike Morris
    April 9, 2005 at 7:46 am
    Nyob Zoo Roadkill…
    Thanks for the link… Very useful information. I am just ticked at Premiere and Encore right now. I’ll get over it someday, I guess
    Ua Tsaug
    Sib Ntsib Dua
    Xeeb
  • Roadkill
    April 9, 2005 at 4:31 pm
    [Xeeb] “Ua Tsaug”
    Tsis ua li cas.
    If you are still considering using a Mac for authoring, maybe this thread on the dvdquestions.com.au forum is of interest.
