Activity Forums Adobe After Effects burning paper effect
  • burning paper effect
    Posted by Sterling Youngman on February 19, 2011 at 12:46 am
    I have an image that I would like to give the effect of it burning from within.
    I don’t want flames. I want a fiery fractal type burn that builds over time.
    I’m not sure if this is clear, but if anyone has ideas, or if you could suggest a plugin, I’d appreciate it.
    Cheers,
    Sterling
    Tudor “ted” jelescu replied 15 years, 6 months ago 3 Members · 2 Replies
  • Brian Charles
    February 19, 2011 at 2:31 am
    Apply Fractal Noise to a solid layer, animate the Brightness and Contrast to begin at white and end with a black plate, animate the evolution.
    Precomp the noise layer.
    Use that as a luma matte on the layer you want to burn.
    You can reuse the fractal noise comp beneath the burning layer and apply Colorama and a glow.
    This sample is a bit lame but it took 2 minutes to make…
    Luma Matte
  • Tudor “ted” jelescu
    February 19, 2011 at 4:34 pm
    Here’s a project using all AE plugins- CC Film Burn, Glow…
    1656_paperburn.aep.zip
    Tudor “Ted” Jelescu
    Senior VFX Artist
