Activity › Forums › Apple Motion › Burning in Install HELL! Please help. ;-)
  • Burning in Install HELL! Please help. ;-)
    Posted by Skip Hunt on September 30, 2005 at 4:38 pm
    Hi, been awhile since I’ve been here. But, I’m absolutely at the end of my rope with this FinalCutStudio install.
    I’m trying to install the upgrade of Studio but the install gets through 2 or 3 disks and then says there was an error, please try again.
    I’ve tried dumping all my old Studio apps and prefs etc. Didn’t help. I reinstalled my OS. Didn’t help
    I dumped the FinalCut System ID and re-entered all serial numbers and that didn’t work. I then bought a new SATA 300GB drive and thought I’d just start all over. I installed OSX Tiger fresh. Then Studio. Still the same problem.
    I then tried installing from an external DVD Burner and the same thing happens. I’ve even tried logging in at Root level to try and install and it’s always the same.
    I found that if I ONLY install the apps themselves, I don’t have a problem. It’s all the content portions of the installs that hang up. So, I tried installing those separately and still the same. Then tried installing to another drive for just content,… same problem. It’s not always the same content disk that hangs either, but mostly it’s the Apple Loops Content CD. But the others fail too if I install them direct of their respective DVDS.
    Does anyone have a clue what might me going on? I don’t have any problems with the DVD drive at all. Have installed many programs, and have burned many DVDs without issue. And, as I stated above… I even tried this fresh, with fresh OSX Tiger on a brand new internal drive. Is there something wrong with my CPU?
    I have a G5 DP 2Ghz – 4.5GB RAM – ATI 9800 Pro (and a second card for tools – Rage 128)
    I’m running OSX Tiger 10.4.2 on the stock 160GB SATA drive, and running the same on the new Maxtor 300GB SATA drive split in 2 partitions.
    I’ve tried just about everything I can possibly think of. Did I miss anything?
    thanks in advance,
    Skip
    Walter Biscardi replied 21 years ago 2 Members · 1 Reply
  • Walter Biscardi
    October 2, 2005 at 9:36 am
    [skip hunt] “Does anyone have a clue what might me going on?”
    Perhaps a damaged disk in the install set? Sounds like you have a problem with the product itself, not the computer. I would call Apple Support and see if they concur and have them ship you out a new product.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
