Activity › Forums › Adobe Premiere Pro › burning for tv, mac and pc
  • burning for tv, mac and pc
    Posted by Phillip Mccordall on October 17, 2013 at 8:39 am
    Hi everybody, I’ve just finished my first dvd, or at least thought I had. i used mpeg 2 for exporting too encore but it won’t read on a pc with the standard media player, can anyone tell me what export setting from premiere pro to encore I need, so it will read on tv,mac and pc.
    Also I’m told that dvd players are multi standard , therefore an ntsc version is not required, is that true.
    Thanks for any reply
    phill
    Phillip Mccordall replied 12 years, 11 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    October 17, 2013 at 5:07 pm
    Not all versions of Windows support DVD playback with Windows Media Player out-of-the-box, especially Windows 8, and some versions of Windows 7. https://windows.microsoft.com/en-us/windows/windows-media-player-plug-ins This is simply to reduce licensing costs for Microsoft.
    Download VLC player and play your DVD from there on Windows to confirm it’s not a bad disc burn or some exotic problem.
    Also, although DVD players may be able to play both PAL and NTSC variant’s, don’t count on them to and don’t count on a TV understanding the signal. Author for each region separately as needed.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Phillip Mccordall
    October 18, 2013 at 8:27 am
    Thankyou for your help much appreciated
    Phill
  • Jeff Pulera
    October 18, 2013 at 1:49 pm
    Hi Phillip,
    It seems that most PAL DVD players will play NTSC DVDs, but not the other way around.
    Regarding the DVD encode, in AME you want to specifically use “MPEG-2 DVD”, and at a bit rate that will allow your footage to fit the disc. If your file is too large, or an incorrect format, then Encore will “transcode” the clip automatically to meet DVD spec, so encoding should not be a part of any incompatibility of the final DVD.
    Use a good quality DVD-R and try the disc on a set-top DVD player, or VLC on PC as mentioned in the other post.
    Jeff Pulera
    Safe Harbor Computers
  • Phillip Mccordall
    October 18, 2013 at 1:55 pm
    Thankyou.
