Activity › Forums › Apple OS X › burning data DVD
  • burning data DVD
    Posted by Josh Snider on November 9, 2005 at 3:41 am
    hi. i’m using 10.3.9 on an iMac G4 with 800MHz processor. i’ve burned a number of data DVD’s, because i am trying to clear off my external hard drive, but neither my iMac nor my PC are able to read them. the iMac read the first data DVD i burned, and that’s why i kept burning more of them, but now it won’t read any of them. i’ve used TDK’s and Phillips, (both cheap DVD-R’s) that I bought primarily for making DVD’s of my videos. any thoughts on why this isn’t working? i’m burning with Roxio Toast 6 Titanium.
    josh
    David Bogie replied 20 years, 10 months ago 4 Members · 4 Replies
  • Peppsirous
    November 9, 2005 at 8:58 pm
    one it happenned something like this to me. but when i restarted the compurter it burned it right. thry restarting it each time you burn one. although is not much logical ..
  • Mitchji
    November 10, 2005 at 1:22 am
    Did you drag the files and folders to Toast using the data tab with Mac and PC checked?
    What speed dit you burn at? Try 4x. If that doesn’t work try 2x or 1x.
    Best Wishes,
    Mitch
  • Josh Snider
    November 10, 2005 at 2:39 am
    i set it to DVD-ROM, and burned it at DVD 1x. i’ll try restarting it and burning. josh
  • David Bogie
    November 13, 2005 at 3:55 pm
    As part of the debugging operation, try bypassing Toast. Read up on using Disk Utility to create disk images that can be burned to DVDs or just drag stuff onto your DVD icon in the Finder.
    bogiesan
