Activity Forums Adobe Premiere Pro burning closed captions to video
  • burning closed captions to video
    Posted by Grzegorz Kwiatkowski on June 4, 2015 at 12:38 pm
    Hello,
    recently in our company we started to edit tv series CC 2014. Every episode has to be reviewed by our employers who speak different language. This requires lot’s of subtitles to be burned in video file. What is the best method for this except standard titles which are rather cumbersome? Can I burn in closed captions in video? In fact there is a nice plugin EZTitles but.. maybe am wrong but it’s ridicously expensive (1580 EUR).
    Thanks for help
    Grzegorz Kwiatkowski replied 11 years, 3 months ago 3 Members · 4 Replies
  • Steve Brame
    June 4, 2015 at 3:31 pm
    A ridiculously simple technique, and free…
    First install ‘Subtitle Edit’, easily found with a Google search. It’s a free subtitle editor that has some nice features.
    Then…
    Create your subtitles in Subtitle Edit, or import almost any subtitle file that you have already created.
    Save as ‘FCP XML + images’ (use PNG’s for image format). Each subtitle will be created as a single PNG graphic. Save these in a folder next to your project’s media.
    Import the resulting XML into Premiere. After you import the XML, Premiere will try to find the PNG’s refereenced in it. You may have to locate the first PNG, since they all will probably be showing as offline, but once you’ve shown Premiere where the first one is, it should locate the rest automatically.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • James Strawn
    June 4, 2015 at 5:33 pm
    PrPro CC next will offer you Open Captions which is what you’re asking for.
    https://blogs.adobe.com/premierepro/2015/04/premiere-pro-next-colorful.html
    “Editors who work with Closed Captions will now be able to burn them into video on export”
    The official release date has not yet been announced. I can’t say any more than that, but keep checking https://www.facebook.com/premierepro for latest info.
  • Grzegorz Kwiatkowski
    June 4, 2015 at 9:35 pm
    It’s a bit workaround but works great. Thanks Steve.
    Anyway Adobe should have implemented subtitle feature long time ago.
    June 4, 2015 at 9:46 pm
    It’s unbelievable they are giving me solution just in time I need it 🙂
