Burning Audio CD from Vegas 10.0c
Posted by Jason O’connell on March 16, 2011 at 12:22 amWe are having some issues burning audio CDs with Vegas 10.0c. The burn appears to be successful but when you put the disc into a CD player it will only have about 5 seconds worth of audio and then goes blank for the rest of the disc.
I’ve seen some similar posts here but no responses. I’ll also post on the Vegas website.
Any ideas?
– Jason
Jason O’connell replied 15 years, 6 months ago 4 Members · 5 Replies -
Steve Rhoden
March 16, 2011 at 1:40 amAny ideas?
….Not really, Vegas handles CD Burning very, very
well. As a matter of fact im using it to burn some CD’s
right now.
Before testing on that particular CD player you are using,
play it back in the computer first and see if it plays well.
If it does, the CD player has a bit of an issue or has an issue
with that particular brand of CD.
But make sure first you are burning your tracks properly,
by even going thru the help menu.Steve Rhoden
(Cow Leader)
Film Maker
Filmex Creative Media.
1-876-832-4956 -
Jason O’connell
March 16, 2011 at 2:06 amSteve-
Thank you for your reply.
I have tried playing these discs back on multiple CD players and computers with no luck. Additionally, I’ve successfully burnt hundreds of discs using Vegas 8.0 with no problem (I agree! The CD burning in Vegas has always been extremely stable). This issue has only cropped up since switching from Vegas 8 to 10.0c. I have tried multiple burns and the audio will drop out at the exact same moment on each burn (yet the same files will burn successfully in Vegas 8).
Strange..
Stephen Mann
March 16, 2011 at 3:59 amHow’s this for irony… I had exactly the same issue just a few minutes ago.
Select Disk At Once. Set the speed to half the maximum available, select “Buffer Underrun protection”, “Render temporary image” and “Eject when done”. then do nothing else on the PC while burning the CD.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Enrique Orozco
March 16, 2011 at 5:41 am…same problem here..I ended rendering my tracks to WAV and burning the CD with Nero…. problem solved..
my 2 cents
Enrique Orozco R.
iDEA DigitalVideoStudio -
Jason O’connell
March 17, 2011 at 3:34 pmThanks Stephen –
I’ll try these setting and see if I have any future problems.
I’ve also noticed doing a ‘Save as’ seems to help too.
Jason
