Activity Forums DVD Authoring Burning a Dual Layer DVD
  • Burning a Dual Layer DVD
    Posted by Steve Mason on July 3, 2015 at 5:21 am
    Hello,
    I’m in the final phases of authoring an intricate DVD, which due to the sheer amount of data it holds must be dual layer. This is to be an instructional and set-up disc, which will accompany a tangible product.
    Further, this is a start-up product; my initial goal is to achieve placement with a few re-sellers by sending out a handful of “beta” DL-DVDs to interested prospects for review. Due to start-up budget constraints and the strong probability of changes to the DVD before wide release, I’d prefer not to invest the approximate $1500.00 on a replication run right now.
    I am using DVD Architect 5.2 for this task; I’ve been compiling and burning iterations of the project for testing as the build develops. The burned discs have thus far worked fine on newer DVD players, including portables; however the same discs have exhibited issues on somewhat older devices, i.e. 5-6 years old.
    Short of the obvious (biting the $1500.00 bullet), are there any recommendations for maximizing compatibility in terms of method, e.g. compile in DVDA and use ImgBurn to set the break point and burning, etc. – just to get up and running?
    Any expert advice is tremendously appreciated.
    PS – When it is time to go to replication, any advice for this same project would be equally appreciated.
    Steve M.
    Rob Neidig replied 11 years, 2 months ago 3 Members · 2 Replies
  • Steve Brame
    July 3, 2015 at 3:07 pm
    Haven’t done much DVD authoring in quite a while, but back when it was our main delivery media, I remember that most player incompatibility problems were due to the brand of media. Where we’d have a compatibility problem on one player, simply burning to a different brand of disc would take care of it, but possibly result in incompatibility elsewhere.
    It got to the point that we created a standard waiver advising a client to use replication rather than duplication, and that failing to do so released us from liability of any player incompatibility claims.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Rob Neidig
    July 6, 2015 at 4:41 pm
    In addition to what Mr. Brame said, I would recommend not using dual layer DVDs at all. No matter what brand disc you use to burn, dual layer discs have compatibility issues on a lot of players. You are far better off splitting your project onto two discs. Even if you are replicating, dual layers can be an issue.
    Have fun!
    Rob
    Rob Neidig
    R&R Media Productions
    Eugene, Oregon
