Activity Forums Avid Media Composer burning 1080/59.94 to DVD issue ASAP
  • burning 1080/59.94 to DVD issue ASAP
    Posted by Caitlin Miller on December 4, 2012 at 10:17 pm
    Hi all,
    I’m creating a playable DVD from high resolution footage (1080/59.94) by exporting a quicktime and creating a dvd in iDVD. My question is, when setting field dominance I am choosing lower field because I read that that what is needed for DVDs, but it seems to be causing some field dominance issues. When there is a lot of movement in the shot, I’m getting that venetian blind effect. What am I doing wrong? Can I create and export with “single field” chosen instead? Would that work for a playable DVD?
    I need to get this out tonight, so any immediate help is much appreciated!
    Shane Ross replied 13 years, 9 months ago 3 Members · 3 Replies
  • Ricky Barrow
    December 5, 2012 at 12:49 pm
    Have you tried upper field?
    Ricky
  • Caitlin Miller
    December 5, 2012 at 3:55 pm
    I tried upper field and got the same result. I’m checking them on a monitor though instead of using a DVD player because I don’t have access to one. Maybe that’s the issue?
  • Shane Ross
    December 5, 2012 at 5:54 pm
    COMPUTER monitor? Sorry, Computer Monitors don’t display interlacing properly. If you need to check a DVD, you need a DVD player and TV. If the intention is for the DVD to be played on a computer, you need to deinterlace.
    Yeah, that’s the problem.
    Shane
    Little Frog Post
