Activity Forums Adobe Premiere Pro Burned DVD perfect, now it says i have to lower the rate. It wont fit..?
  • Burned DVD perfect, now it says i have to lower the rate. It wont fit..?
    Posted by Mozwald on April 4, 2007 at 2:00 am
    I have about 1min 25seconds worth of some edited graphics and uncompressed video files. I burned the timeline to DVD using premiere pro 2 “Export to DVD.” I used VBR 2 pass and set min rate to 5, max to 9, and target to 8. PCM audio. Burned perfectly, and looked amazing….now here is the problem.
    The boss wanted a couple font changes and the entire thing to be basically “shortened.” So I cut about 25 seconds off and did some minor font changes, as well as adding an extra, small graphic. Now it wont burn, it will encode but it says I need to lower the rate to fit.
    The animation is shorter now, and maybe a few kbs worth of added graphics. Why wont it work all of a sudden? Shouldn’t I be able to increase the bit rate overall?
    Vince Becquiot replied 19 years, 5 months ago 2 Members · 1 Reply
  • Vince Becquiot
    April 4, 2007 at 3:15 am
    For footage under 1 hr, use CBR 8.
    9 is too high for any burner, and you might start to see errors.
    2 Pass VBR won’t make any difference in quality for that small amount of time, you’ll simply more than double the render time.
    Vince
