Activity › Forums › DVD Authoring › burned disk not like simulator version in DVDSP 3.0.2
  • Randall
    April 27, 2007 at 2:21 pm
    Thanks, Don. I should know something by the end of today. I really appreciate your taking the time to help. Randall
  • Randall
    April 28, 2007 at 3:57 am
    Don–It works! I first built it using a template from the palette to see if the buttons would function properly. Then I replaced the palette background with my own, and it works perfectly. I think the whole problem was that I was left-justifying the button text. This time around I centered it and moved the entire button to the left margin of the frame. Using the Build/Format and disk image routine you explained to me is what saved the day. I am really grateful for your help. Randall
  • Don Greening
    April 28, 2007 at 5:03 am
    Exellent! Glad everything worked out for you. You mentioned in a previous post about the text issue. I guess now we know that the text has to be pretty much right underneath the buttons for them to be activated properly.
    Best,
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Randall
    April 28, 2007 at 8:12 am
    That seems to be it. Makes you wonder why there are left and right justify options if they prevent the buttons from functioning properly. It was a hard lesson to learn, but it is learned. Thanks, Don. Randall
Page 2 of 2
