Activity Forums Adobe Premiere Pro Burn to DVD question
  • Burn to DVD question
    Posted by Julie Allen on June 10, 2007 at 3:45 am
    My second question is:
    Is there a faster way to export to DVD, other than to choose the “burn to DVD” option in the export menu. Just curious.
    Thank you!
    Mike Velte replied 19 years, 2 months ago 3 Members · 3 Replies
  • Mike Velte
    June 10, 2007 at 10:09 am
    If you need only one copy, the Burn to DVD option is ok, but the Burn to Folder option is by far faster if you anticipate needing more copies later. Once the VIDEO_TS folder is created you can use your DVD burning app to create copies in just a few minutes each.
    There are several settings in the encoder that can cause slow encoding;
    The worst offender is the Quality slider which is by default set to 5. Moving it to 3 will result is much faster encoding with no noticeable effects on quality.
    Also, 2 pass VBR takes twice as long as single pass CBR and does little good if your movie is 75 minutes or less.
  • Steven L. gotz
    June 11, 2007 at 12:13 am
    Hey Mike!
    Is it better to burn to a folder than to burn an ISO file, and if so, why? I never gave it much thought until I just read your post. Do you know?
    Steven
    https://www.stevengotz.com
  • Mike Velte
    June 11, 2007 at 9:36 am
    [Steven L. Gotz] “Do you know?”
    No, other than an advantage of transferring the data over the internet in a zipped or archived format.
    I never had an issue with the folder option.
