Activity Forums DVD Authoring Burn movie to Blu-ray?
  • Burn movie to Blu-ray?
    Posted by Andrew Harman on February 24, 2011 at 10:27 pm
    First time post and not sure if its in the right area.
    I have a file generated from Fotomagico Pro. as you can see, when i open the file in quicktime on the mac, its looks great and seems the right specs.
    Essentially the end aim is to have this look as good on a hi-def LCD screen (we have a 52 inch).
    I know the screen at hi-def is 1920×1080.
    Its just when i burn the blu-ray through Toast, its not looking as crisp.
    I may be doing it wrong or the disc is as good as it will be.
    Help!!
    Thanks All
    Daniel Ludwig replied 15 years, 6 months ago 3 Members · 3 Replies
  • Daniel Ludwig
    February 25, 2011 at 7:37 am
    hi andrew,
    the first question would be: did you create your sliedshow in 1080? if not – your programm will be upscaled that wont result in good, crispy quality.
    another point: toast encoding is no high-quality encoding – so if you would like to have a nice picture I would advice to use adobe encore for BD-authoring and do the encoding using adobe media encoder, apple compressor or even better.
    another issue is your BD-player or display. I don´t know what you´ve done: 1080interlaced or 1080progressive.
    depending on your player-setting it wont be displayed correct on screen – maybe it would be deinterlaced where it is progressive or wise versa.
    this all gives you a bad picture.
    you see, there are several gaps to be awared.
    cheers
    danny
  • Michael Slowe
    February 25, 2011 at 4:48 pm
    Daniel, I’m surprised what you say about Toast’s BD encoding. I’m dragging to Toast 10 a ProRes HQ 422 QT .mov file (1920 X 1080i) and getting great BD’s. They look fantastic and even examined close up on a big screen there is no noise and a great picture. Are saying that a BD encoded in Encore would be even better?
    Michael Slowe
  • Daniel Ludwig
    February 25, 2011 at 4:53 pm
    hi michael,
    both programms using the same source-code: mainconcept encoder engine, but you have less possibilities to set within toast.
    I´ve seen a lot toast-encodings and they mostly have been bad.
    I would prefer to use adobe media encoder or compressor instead and do the authoring within encore.
    cheers
    danny
