Activity Forums Panasonic Cameras Burn in Timecode via Firewire
  • Burn in Timecode via Firewire
    Posted by Justyot on February 13, 2006 at 8:49 am
    Is there a way to capture the timecode via firewire using the display settings? Or is it for VHS/Composite recording’s only?
    yot
    (using Adobe Premier Pro 1.5)
    Steve Wargo replied 20 years, 7 months ago 3 Members · 2 Replies
  • Ben Insler
    February 14, 2006 at 6:44 pm
    I don’t think so. The timecode you’re seeing is a display of the TC on the tape – it is not video footage in any way (the same way your audio monitors aren’t recorded as video footage). I believe you’d have to put in a TC burn in post and re-record do what you suggested, set the display to run out of your composite display and make a dub that way.
    Best,
    Ben Insler
    Editor
    Telemark Films
  • Steve Wargo
    February 15, 2006 at 3:25 am
    It can be embedded in your composite signal only and you have to turn it on with the disply button under the flip out screen (I think)
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
