Activity › Forums › Apple Final Cut Pro Legacy › burn in time code on a sequence with fcp7
  • burn in time code on a sequence with fcp7
    Posted by Stephen Johnson on November 20, 2009 at 9:37 pm
    Hi
    I am trying to add a time code window to a short sequence (12 minute) in FCP 7 I used the timecode generator filter but it resets to zero at every edit so that doesn’t work. then I put black slug on a second video track and keyed out the dark and that was fine but it seems I can only lay down 2 minutes of black at a time so the time code window goes away at the edit of each section of slug, I would happily reset the time code generator at each cut to provide accurate window but I cannot seem to be able to tell the timecode generator where to start the code,
    any help
    Stephen Johnson replied 16 years, 10 months ago 2 Members · 2 Replies
  • Paul Figgiani
    November 20, 2009 at 9:47 pm
    Nest the sequence and add the TC Generator Filter to it. Or use Andy’s TC Generator above the existing edited sequence.
    -paul.
  • Stephen Johnson
    November 21, 2009 at 7:04 am
    paul …..
    thanks so much, that worked great
    steve
