Activity Forums Compression Techniques Burn footage timecode on output???
  • Burn footage timecode on output???
    Posted by Andrew G. on December 28, 2005 at 9:15 pm
    I’m using my iPod to review footage on the road, since I don’t have a laptop to perform rough-cuts. Does anyone know of any software that can take captured footage (Quicktime DV) and detect the embedded timecode, then output to H.264/MPEG-4?
    So far, I’ve successfully imported about 8 hours of MPEG-4 footage into my iPod, but had to perform the following steps after capturing:
    -Apply “Timecode Reader” filter from Final Cut Pro
    -Export directly to Apple Compressor
    The processing time typically takes about 45min for every hour of processed footage. Total a/v data rate is about 970kbps. Quality is good, but not great (see below). I’m just wondering if there is any software with a feature to embed timecode on output. Thanks!
    Another thing…after reviewing the processed footage from Compressor, the only issue I had with the quality is that during playback, there’s a huge compression artifact that covers the entire frame for a millisecond, which occurs about every second. It looks the entire video flashes a “mosaic” effect. On my 2min videos, I don’t see it. But on my 15min-long clips, it’s there.
    I’m using Compressor v.1 (don’t know which build) and applied the MPEG-4 preset “MPEG-4 NTSC 768kbps.” Any suggestions?
    Andrew
    Charles Simonson replied 20 years, 8 months ago 2 Members · 1 Reply
  • Charles Simonson
    December 31, 2005 at 6:31 am
    Apple’s MPEG-4 Part 2 encoder is not that great. The MPEG-4 encoder included with Popwire’s Compression Master 3 is the best software MPEG-4 encoder anywhere in terms of quality and one of the fastest as well. CM3 can also preserve timecode for your encodes.
