Activity Forums Adobe After Effects Burn away effect
  • Burn away effect
    Posted by Richard Windsor on March 30, 2015 at 7:55 pm
    I am trying to create a transition from one clip to another where the clip on top burns away very realistically. Does anyone know a good tutorial or way to do this past using the film burn with glow and roughen edges. That effect is ok but looking for something a bit more realistic.
    Richard Windsor replied 11 years, 5 months ago 3 Members · 3 Replies
  • Claude Rozsa
    March 31, 2015 at 5:55 am
    You could check Video copilot for their Heat distortion plugins. And you have also this link which implies buying the effect or footage. https://www.youtube.com/watch?v=8ZOHansLZdw
    Claude
  • John Cuevas
    March 31, 2015 at 2:12 pm
    Check out this tutorial, should give you a good starting point. Creating Fire with Fractal Noise
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Windsor
    March 31, 2015 at 5:27 pm
    [John Cuevas] “Creating Fire with Fractal Noise”
    Thanks this should help a bit.
