Activity Forums Adobe After Effects Bumpy camera path
  • Bumpy camera path
    Posted by Michael Gagliano on March 6, 2006 at 8:20 am
    I have a path that I have a camera following. The camera is using the keyframes from a masks shape, I pasted them into the position of the camera. Whenver the camera goes through a arc, when it hits keyframes, it”bumps”.
    The arcs are smooth, and there are minimal keyframes making up the arc. Thanks
    Hemanth Kumar replied 20 years, 5 months ago 3 Members · 2 Replies
  • Al
    March 6, 2006 at 9:37 am
    have you tried looking at the position keyframe graph? access it by twirling down the triangle next to position… most likely it’s a speed issue… if you haven’t used the graphs before, try being in this view and try highlighting your keyframe and clicking it once so it becomes a circle, this will give you a default – you may need to manually adjust it.
  • Hemanth Kumar
    March 6, 2006 at 10:53 am
    You could also use rooving keyframe to make it even smoother
    regards
    Hemanth
