Activity Forums Maxon Cinema 4D Bump Map not rendering (little red circle indicator?)
  • Bump Map not rendering (little red circle indicator?)
    Posted by Joe Vandalsem on July 24, 2009 at 8:43 pm
    Hi, for some reason, my bump map isn’t rendering and it’s unchecking itself whenever i change frames on the timeline. Now, if I do a live region render, it will render the bumpmap, but if I do an actual render, it doesn’t.
    There is a little red circle next to the bump map section in the materials editor. And that can’t be good but I can’t find out how to correct for this. Or what is causing the red circle to appear. My bump material is a greyscale .bmp image. Also tried grayscale .jpg to see if that was the cause. The bump is being applied to a text spline with extrude nurbs applied.
    It’s really weird that it CAN render in interactive render region and render view. Anybody know what can be causing this? Thank you!
    Brian Jones replied 17 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    July 25, 2009 at 5:23 am
    I think you must have accidently set a keyframe on the Bump property there (is the bump on or not). Just right-click on “Bump” and mouse over Animation (top one) then choose Delete Track in the contextual menu that pops up.
