Activity › Forums › Adobe After Effects › bump map in AE?
bump map in AE?
Posted by Marc De coster on September 27, 2010 at 7:53 amHi guys.
I think that what I have to do is quite easy but I can’t find my effect back!!! I’d like to make a “bump map” effect and use the luminance of a picture to create some “relief” in a texture. But there is no “bump map” effect in AE. I tried with the displacement map but it’s really not what I need! I also put a bevel but it only works with edges or alpha.
Any ideas?
Thanx a lotMarc
Marc De coster replied 15 years, 11 months ago 6 Members · 10 Replies -
Tudor “ted” jelescu
September 27, 2010 at 1:53 pmDisplacement map is what you’re after. Digieffects Free Form comes now with CS5 and allows for true 3D displacement. You can check out my tutorial about this subject:
https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
Tudor “Ted” Jelescu
Senior Compositor/VFX Artist -
Michael Szalapski
September 27, 2010 at 3:08 pmWhat didn’t work for you with the Displacement Map?
As Ted mentions, it’s not 3d like Freeform.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Marc De coster
September 27, 2010 at 3:35 pmHi guys, thank U for the answers but it doesn’t help! I had a look to the digieffect plugin.
I didn’t use the basic displacement map because I don’t need a distortion. I have a velvet texture (full screen) and I want to have an effect that looks like I pushed a little bit an object from behind the velvet, so I could see, thanks to the shadows, “the Cardinal Richelieu” profile! What I have now, is the outline of the profile, thanks to a bevel alpha. It lokks ok but what I need now is the inside of it …
The digiEffect Free Form would make it but I don’t have it. Several years ago, I used to work with Combustion and there was an effect called “Bump map” and it was exactly what I need! Sounds familiar to you?
Adriano Moraes
September 27, 2010 at 3:56 pmHi there. Sometimes the plugin Texturize works for me in similar situations if I´m getting what you want.
Hope it helps.
Cheers.
Kevin Camp
September 27, 2010 at 4:06 pmyep, texturize comes to mind… it’s a compound effect, so you could apply it to the velvet layer, then choose the other layer as the texture. it would then create a kind of emboss effect on the velvet layer.
also emboss and color emboss may help… neither are compound effects, so you would add them to the layer that you wanted to make the bump texture from, then use blending modes or other effects to mix it with the velvet layer.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Marc De coster
September 27, 2010 at 4:07 pmThank U Adriano. It’s indeed the kind of effect I was looking for. If I copy my layer, desaturate and contrast it, blur it a little bit, and then use it as a reference for the texture effect it’s looks almost like what I had in mind! Well, it’s not perfect but I’ll deal with it!
Thank U all guys
Marc De coster
September 27, 2010 at 4:14 pmyep again! An emboss with an overlay mode will make it! In french we say “it’s in the old pans that you prepare the best meals”. Well, it seems like it’s right! I thought I’d never use that filter again! Today is the day I change my mind! Thank U
Shawn Miller
September 27, 2010 at 8:26 pmYou might also consider Z-Born Toy… it seems like it would be pretty handy for the effect you’re describing.
Shawn
Tudor “ted” jelescu
September 28, 2010 at 8:54 amHere’s what you can get with FreeForm:
https://www.youtube.com/watch?v=s3Pc1YWK0t4Tudor “Ted” Jelescu
Senior Compositor/VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Marc De coster
September 28, 2010 at 10:53 amCool.Thank U for having spent some time on this! It looks ok. But I had to deal with the basics because I didn’t have the plugin. So I used the emboss for the inside and I used bevel alpha for the borders. It looks like this:
https://www.youtube.com/watch?v=Vki9Zp7tqWo
I think it works quite well. Thank U anyway!
