Activity Forums Maxon Cinema 4D bump map displacement map?
  • bump map displacement map?
    Posted by Chad Demoss on April 28, 2016 at 4:49 pm
    I have an object that I UV texture mapped on and I want parts of the texture to bulge out like a puffy jacket. I tried bump map and that is just faking it and doesn’t look right. I thought a displacement map would work but its not working or i have the wrong settings. attached is screen grabs of what the bump map is doing and another image of a puffy jacket is the kind of effect Im trying to achieve.
    Brian Jones replied 10 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    April 28, 2016 at 6:51 pm
    displacement needs enough geometry to move around to look reasonable so you have to subdivide the mesh enough for it to work like you want
