Activity Forums Boris FX Particle Illusion Bullets hitting the ground
  • Bullets hitting the ground
    Posted by Choc_tpot on March 14, 2006 at 4:59 pm
    Im trying to achieve the effect of bullets hitting the ground. You know like when a helicopter flies over and its machine guns are shooting at the ground and you see the dust thrown straight up. Anyone know how I can do that?
    Im also trying to achieve the same effect on a larger scale, to give the impression of a huge projectile smashing into the desert.
    Elvis Deane replied 20 years, 6 months ago 3 Members · 2 Replies
  • Jose Burgos
    March 15, 2006 at 4:40 am
    Play with the dust puff emmiter.
    Take care,
    Jose Burgos
  • Elvis Deane
    March 15, 2006 at 5:28 am
    There are two that do exactly this sort of thing in one of the Eclectic pro-emitter libraries, but if you don’t have those you can probably use Boom 5 from the June 2003 library for the larger impact, and with a little editing it can probably do bullet hits as well.
    There’s also a few Rain Splash emitters in the May 2005 library that would probably work quite well if you convert them to a point emitter and animate their position. It might not be as dramatic an effect as you’re looking for though.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
