Activity › Forums › Adobe After Effects › Bullet whole / splintering wood effect?
  • Bullet whole / splintering wood effect?
    Posted by Conzy on November 9, 2007 at 9:01 pm
    I need to achieve the effect of some bullets bursting through a wooden door and making a hole ans splintering some wood for a film im working on.
    I have a front on shot of the scene, and a plate of just the door and a plate of the outside scenery behind the doors…
    I was thinking of using the shatter plugin to try and shatter some parts of the door…
    Any other ideas? How do I make a realistic bullet hole in a wooden door? Metal doors are a lot easier 🙂
    Any help greatly appreciated
    Steve Roberts replied 12 years, 2 months ago 3 Members · 3 Replies
  • Steve Roberts
    November 10, 2007 at 2:54 pm
    Yep, use shatter. You’ll need to make a shatter map for the splinters of wood. There should be some shatter tutorials on the COW.
    AE doesn’t always give the most realistic results.
    For something more realistic, use a 3D app.
    For something more realistic than that, reshoot with a practical effect on set.
    But you knew that. 🙂
  • Liza Ray
    July 19, 2014 at 5:43 am
    I find this very interesting but how to implement it is still a big question.
  • Steve Roberts
    July 20, 2014 at 10:42 pm
    Probably the best way is to find an image of a bullet hole in wood and composite that into your shot. Cut from no-hole to hole. For the flying debris, apparently Video Copilot’s “action essentials” may have what you need.
    Now, if we wanted realistic close-up flying splinters and all, especially in slow motion, we’re probably best hiring a 3D animator. In my opinion, AE is good for faking it, not for realistic close-up CGI.
